跳转到主内容
Dell XPS 13 9305 Battery Replacement
你所需要的
  1. Dell XPS 13 9305 Battery Replacement, Remove the back screws: 步骤 1 中的图像 1,2 Dell XPS 13 9305 Battery Replacement, Remove the back screws: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 Battery Replacement, Release the clips: 步骤 2 中的图像 1,2 Dell XPS 13 9305 Battery Replacement, Release the clips: 步骤 2 中的图像 2,2
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 Battery Replacement, Remove the back cover: 步骤 3 中的图像 1,3 Dell XPS 13 9305 Battery Replacement, Remove the back cover: 步骤 3 中的图像 2,3 Dell XPS 13 9305 Battery Replacement, Remove the back cover: 步骤 3 中的图像 3,3
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: 步骤 4 中的图像 1,3 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: 步骤 4 中的图像 2,3 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: 步骤 4 中的图像 3,3
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 Battery Replacement, Unfasten the battery: 步骤 5 中的图像 1,2 Dell XPS 13 9305 Battery Replacement, Unfasten the battery: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to remove the five screws securing the battery:
    • Four 2.4 mm-long screws
    • One 4.4 mm-long screw
  6. Dell XPS 13 9305 Battery Replacement, Remove the battery: 步骤 6 中的图像 1,3 Dell XPS 13 9305 Battery Replacement, Remove the battery: 步骤 6 中的图像 2,3 Dell XPS 13 9305 Battery Replacement, Remove the battery: 步骤 6 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
125,007 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
一条评论
This replacement was extremely simple. I have some experience from years ago when I replaced laptop parts during an internship, but was worried things might have gotten a lot more complicated in the 15+ years since. But it was super easy. This guide + the toolkit made it an absolute breeze. I was actually surprised how easy this was. I'm convinced almost anyone can do this. Thanks for the tutorial!
Bono - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 50
过去 30 天: 198
总计 2,112
