跳转到主内容
加入维修社区 - 创建账户
Dell Vostro A860 Display Replacement
你所需要的
    1. Dell Vostro A860 Display Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Vostro A860 Display Replacement, Keyboard: 步骤 1 中的图像 2,2
      • Make sure the computer is powered down before beginning your work
      • Remove the battery and set it aside, there is a small clip that slides to free the battery.
      • Unscrew the two 4.7mm screws below the battery.
      询问修复机器人
      添加评论
    2. Dell Vostro A860 Display Replacement: 步骤 2 中的图像 1,2 Dell Vostro A860 Display Replacement: 步骤 2 中的图像 2,2
      • Remove seven 8.6mm screws from the left and right side of the battery compartment
      • There are 2 screws to the left of the compartment, 3 to the right, and 2 along the bottom side.
      询问修复机器人
      添加评论
    3. Dell Vostro A860 Display Replacement: 步骤 3 中的图像 1,3 Dell Vostro A860 Display Replacement: 步骤 3 中的图像 2,3 Dell Vostro A860 Display Replacement: 步骤 3 中的图像 3,3
      • Flip the laptop over and open it up.
      • Using a plastic opening tool carefully pry up along the edge of the plastic bezel at the top of the keyboard.
      • Getting the lip of the plastic opening tool under the edge of the bezel and moving it along the right and left edges helps to make removal easier.
      询问修复机器人
      添加评论
    4. Dell Vostro A860 Display Replacement: 步骤 4 中的图像 1,2 Dell Vostro A860 Display Replacement: 步骤 4 中的图像 2,2
      • Remove two 5.5mm screws from the top of the keyboard
      • Using a plastic opening tool push inward along the edges of the keyboard to release the holding clips
      询问修复机器人
      添加评论
    5. Dell Vostro A860 Display Replacement: 步骤 5 中的图像 1,1
      • Lift the keyboard upwards
      • Be careful not to pull too hard on the keyboard as it is still attached to the laptop by the ribbon connector.
      • Using the plastic opening tool push up on the black clip holding the connector ribbon.
      • Pull out the ribbon connector to remove the keyboard.
      询问修复机器人
      添加评论
    1. Dell Vostro A860 Display Replacement, Display: 步骤 6 中的图像 1,3 Dell Vostro A860 Display Replacement, Display: 步骤 6 中的图像 2,3 Dell Vostro A860 Display Replacement, Display: 步骤 6 中的图像 3,3
      • Using a plastic opening tool remove the rubber bumpers covering the display bezel screws.
      • Remove the six 5.5mm screws holding the bezel on.
      询问修复机器人
      添加评论
    2. Dell Vostro A860 Display Replacement: 步骤 7 中的图像 1,2 Dell Vostro A860 Display Replacement: 步骤 7 中的图像 2,2
      • Using a plastic opening tool carefully pry along the edges of the screen bezel to remove it.
      • Once the opening tool is inserted under the lip of the bezel simply sliding it along the edge will release the retaining clips.
      询问修复机器人
      添加评论
    3. Dell Vostro A860 Display Replacement: 步骤 8 中的图像 1,2 Dell Vostro A860 Display Replacement: 步骤 8 中的图像 2,2
      • Remove the following screws:
      • Two 4.7mm screws from the left side of the display.
      • Two 4.7mm screws from the right side of the display.
      询问修复机器人
      添加评论
    4. Dell Vostro A860 Display Replacement: 步骤 9 中的图像 1,3 Dell Vostro A860 Display Replacement: 步骤 9 中的图像 2,3 Dell Vostro A860 Display Replacement: 步骤 9 中的图像 3,3
      • Two 5.5mm screws from the left display mount.
      • Two 5.5mm screws from the right display mount.
      • Gently pull the display mount frame outward to release the inserts holding the display screen in place. This will allow the screen to lean forward, revealing the connectors.
      询问修复机器人
      添加评论
    5. Dell Vostro A860 Display Replacement: 步骤 10 中的图像 1,3 Dell Vostro A860 Display Replacement: 步骤 10 中的图像 2,3 Dell Vostro A860 Display Replacement: 步骤 10 中的图像 3,3
      • Using a flat headed tool or nail, remove the wires from the right connector behind the display.
      • Using a flat headed tool or nail, disconnect the wires from the left connection behind the display.
      • Pulling upward gently on the tab, remove the magnetic connection in the top left of the tray area under the keyboard.
      • The screen should now be able to freely be removed from the laptop.
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G5
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 39
总计 991
