跳转到主内容
加入维修社区 - 创建账户
Dell Vostro 500 Memory Module Replacement
你所需要的
    1. Dell Vostro 500 Memory Module Replacement, Removing the Battery: 步骤 1 中的图像 1,1
      • Slide the battery release latch toward the side of the computer until it is engaged.
      • Slide the battery out of the bay.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      询问修复机器人
      添加评论
    1. Dell Vostro 500 Memory Module Replacement, Removing the Cover: 步骤 2 中的图像 1,1
      • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
      询问修复机器人
      添加评论
    2. Dell Vostro 500 Memory Module Replacement, Popping up the Memory Module: 步骤 3 中的图像 1,1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了6,888篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 341
