跳转到主内容
加入维修社区 - 创建账户
Dell Vostro 1700 Memory Module Replacement
你所需要的
  1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: 步骤 1 中的图像 1,1
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
    询问修复机器人
    添加评论
  2. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: 步骤 2 中的图像 1,1
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
    添加评论
  3. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: 步骤 3 中的图像 1,1
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
    询问修复机器人
    添加评论
  4. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: 步骤 4 中的图像 1,1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,003篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 40
总计 474
