跳转到主内容
加入维修社区 - 创建账户
Dell Vostro 15 Memory Module Replacement
你所需要的
  1. Dell Vostro 15 Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
    询问修复机器人
    添加评论
  2. Dell Vostro 15 Memory Module Replacement, Hinge Cover: 步骤 2 中的图像 1,1
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
    询问修复机器人
    添加评论
  3. Dell Vostro 15 Memory Module Replacement, KeyBoard: 步骤 3 中的图像 1,1
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
    询问修复机器人
    添加评论
  4. Dell Vostro 15 Memory Module Replacement, Memory Module: 步骤 4 中的图像 1,1
    • Lift the memory module cover But Do Not Remove It.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,003篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 302
