你所需要的
Slide the battery latches apart to the unlock position.
Lift the battery from the computer.
Remove the six screws that secure the access panel to the computer.
Remove the access panel from the computer.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the first module pops up.
Slide the memory module from its socket and remove the module from the computer.
另外一个人完成了本指南。
