跳转到主内容
加入维修社区 - 创建账户
Dell Venue 8 Display Replacement
你所需要的
    1. Dell Venue 8 Display Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,1
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
      询问修复机器人
      添加评论
    2. Dell Venue 8 Display Replacement: 步骤 2 中的图像 1,3 Dell Venue 8 Display Replacement: 步骤 2 中的图像 2,3 Dell Venue 8 Display Replacement: 步骤 2 中的图像 3,3
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
      添加评论
    1. Dell Venue 8 Display Replacement, Battery: 步骤 3 中的图像 1,1
      • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
      询问修复机器人
      添加评论
    2. Dell Venue 8 Display Replacement: 步骤 4 中的图像 1,1
      • Gently pry the battery away from the device with the plastic opening tool to remove it.
      • The battery is held on to the tablet by a light adhesive
      询问修复机器人
      添加评论
    1. Dell Venue 8 Display Replacement, Speaker: 步骤 5 中的图像 1,1
      • Using your plastic opening tool, unclip the speaker connection from the logic board.
      • Caution: Pull directly up, not out, on the connection
      添加评论
    2. Dell Venue 8 Display Replacement: 步骤 6 中的图像 1,1
      • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
      • The speaker is held on by light adhesive
      询问修复机器人
      添加评论
    1. Dell Venue 8 Display Replacement, Display: 步骤 7 中的图像 1,2 Dell Venue 8 Display Replacement, Display: 步骤 7 中的图像 2,2
      • Disconnect the display clip found next to the speaker.
      • Disconnect the Display connection located at the top of the tablet.
      询问修复机器人
      添加评论
    2. Dell Venue 8 Display Replacement: 步骤 8 中的图像 1,1
      • Unclip the logic board from the Display.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Mitul
于02/19/15注册
673 声望
撰写一个指南
团队
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G2
3 名成员
创作了12篇指南
2指南评论
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - 回复 分享
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 7,706
