跳转到主内容
加入维修社区 - 创建账户
Dell VRC100-R Battery Replacement
    1. Dell VRC100-R Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell VRC100-R Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell VRC100-R Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      询问修复机器人
      添加评论
    2. Dell VRC100-R Battery Replacement: 步骤 2 中的图像 1,2 Dell VRC100-R Battery Replacement: 步骤 2 中的图像 2,2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Kenneth Liu
于04/18/18注册
169 声望
创作了2篇指南
团队
Cal Poly, Team S18-G3, Livingston Spring 2018 Cal Poly, Team S18-G3, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G3
4 名成员
创作了15篇指南
1指南评论
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 1,210
