跳转到主内容
加入维修社区 - 创建账户
Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 步骤 1 中的图像 1,2 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 步骤 1 中的图像 2,2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
    询问修复机器人
    添加评论
  2. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: 步骤 2 中的图像 1,1
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
    询问修复机器人
    添加评论
  3. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 步骤 3 中的图像 1,2 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 步骤 3 中的图像 2,2
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
    询问修复机器人
    添加评论
  4. Dell Precision T3400 Video Card Replacement, Remove the video card: 步骤 4 中的图像 1,1
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
    询问修复机器人
    添加评论
  5. Dell Precision T3400 Video Card Replacement, Install the new video card: 步骤 5 中的图像 1,2 Dell Precision T3400 Video Card Replacement, Install the new video card: 步骤 5 中的图像 2,2
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.\
    • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
取消:我没有完成这个指南。
8等其他人完成本指南。
团队
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G2
3 名成员
创作了14篇指南
1指南评论
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 65
总计 7,416
