跳转到主内容
加入维修社区 - 创建账户
Dell Precision T3400 RAM Replacement
你所需要的
  1. Dell Precision T3400 RAM Replacement, Power down the PC.: 步骤 1 中的图像 1,1
    • If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
    • Unplug the PC from the wall.
    • Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
    • Press the power button after completely shutting down the PC. This will "ground" the motherboard, preventing any short circuiting from occurring.
    询问修复机器人
    添加评论
  2. Dell Precision T3400 RAM Replacement, Remove the computer's side panel.: 步骤 2 中的图像 1,2 Dell Precision T3400 RAM Replacement, Remove the computer's side panel.: 步骤 2 中的图像 2,2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
    询问修复机器人
    添加评论
  3. Dell Precision T3400 RAM Replacement, Remove the RAM: 步骤 3 中的图像 1,1
    • Press down on both of the two secure tabs on each side of the RAM stick.
    • When you simultaneously press each of the secure tabs, the RAM stick will move up and out of its slot.
    询问修复机器人
    添加评论
  4. Dell Precision T3400 RAM Replacement, Re-install the new RAM: 步骤 4 中的图像 1,1
    • Align the notch on the bottom of the RAM stick with the notch in the slot.
    • To avoid damage to the RAM, press the stick straight down into the slot using equal force on each end of the stick.
    • Insert the RAM stick into the slot until the stick snaps into position. If you insert the stick correctly, the secure tabs will snap into the notches on each side.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G2
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 31
总计 3,756
