跳转到主内容
加入维修社区 - 创建账户
Dell Precision M6400 Memory Module Replacement
你所需要的
    1. Dell Precision M6400 Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
      • Slide the battery release latch and remove the battery.
      询问修复机器人
      添加评论
    1. Dell Precision M6400 Memory Module Replacement, Base Cover: 步骤 2 中的图像 1,1
      • Remove the two M2 x 3-mm screws.
      • Slide the cover toward the front of the computer to release the tabs from the base assembly.
      • Remove the cover from the base assembly.
      询问修复机器人
      添加评论
    1. Dell Precision M6400 Memory Module Replacement, LED Cover: 步骤 3 中的图像 1,1
      • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
      询问修复机器人
      添加评论
    1. Dell Precision M6400 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 1,1
      • Remove the four M2 x 3-mm screws along the top of the keyboard.
      • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
      • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
      询问修复机器人
      添加评论
    1. Dell Precision M6400 Memory Module Replacement, Memory Module: 步骤 5 中的图像 1,1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了5,978篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 40
总计 1,762
