跳转到主内容
加入维修社区 - 创建账户
Dell Precision M3800 RAM (Memory) Replacement
你所需要的
    1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Be sure to power off and unplug your device before you begin your repair.
      • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
      • iFixit’s magnetic project mat is great for keeping the screws in one place.
      • Lift up the silver cover from the back panel to reveal two screws.
      • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
      添加评论
    2. Dell Precision M3800 RAM (Memory) Replacement: 步骤 2 中的图像 1,1
      • Use an opening tool to pry around the edges of the back panel to loosen the panel.
      • Remove the back panel.
      询问修复机器人
      添加评论
    1. Dell Precision M3800 RAM (Memory) Replacement, Battery: 步骤 3 中的图像 1,1
      • Disconnect the battery cable from the system board [1].
      • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
      • Lift the battery off the computer [2].
      询问修复机器人
      添加评论
    1. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): 步骤 4 中的图像 1,3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): 步骤 4 中的图像 2,3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): 步骤 4 中的图像 3,3
      • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
      • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 728
