跳转到主内容
加入维修社区 - 创建账户
Dell Precision M3800 Fan Replacement
你所需要的
  1. Dell Precision M3800 Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    添加评论
  2. Dell Precision M3800 Fan Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    询问修复机器人
    添加评论
  3. Dell Precision M3800 Fan Replacement, Fan: 步骤 3 中的图像 1,2 Dell Precision M3800 Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
    询问修复机器人
    添加评论
  4. Dell Precision M3800 Fan Replacement: 步骤 4 中的图像 1,3 Dell Precision M3800 Fan Replacement: 步骤 4 中的图像 2,3 Dell Precision M3800 Fan Replacement: 步骤 4 中的图像 3,3
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
    询问修复机器人
    添加评论
  5. Dell Precision M3800 Fan Replacement: 步骤 5 中的图像 1,2 Dell Precision M3800 Fan Replacement: 步骤 5 中的图像 2,2
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 30
总计 1,742
