跳转到主内容
加入维修社区 - 创建账户
Dell Precision 7710 Memory Module Replacement
你所需要的
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
    添加评论
  2. Dell Precision 7710 Memory Module Replacement, Battery: 步骤 2 中的图像 1,1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
    询问修复机器人
    添加评论
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: 步骤 3 中的图像 1,1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
    询问修复机器人
    添加评论
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 1,2 Dell Precision 7710 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 2,2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
    询问修复机器人
    添加评论
  5. Dell Precision 7710 Memory Module Replacement: 步骤 5 中的图像 1,1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
    询问修复机器人
    添加评论
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: 步骤 6 中的图像 1,1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    询问修复机器人
    添加评论
  7. Dell Precision 7710 Memory Module Replacement: 步骤 7 中的图像 1,1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,003篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 29
总计 2,396
