跳转到主内容
加入维修社区 - 创建账户
Dell Precision 7510 Memory Module Replacement
你所需要的
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: 步骤 1 中的图像 1,1
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
    询问修复机器人
    添加评论
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: 步骤 2 中的图像 1,1
    添加评论
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: 步骤 3 中的图像 1,1
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
    询问修复机器人
    添加评论
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
    添加评论
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: 步骤 5 中的图像 1,1
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
    询问修复机器人
    添加评论
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: 步骤 6 中的图像 1,1
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
    询问修复机器人
    添加评论
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: 步骤 7 中的图像 1,1
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
    添加评论
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: 步骤 8 中的图像 1,1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,003篇指南
1指南评论
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 73
总计 12,005
