跳转到主内容
Dell Latitude 7490 Battery Replacement
你所需要的
  1. Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Dell Latitude 7490 Battery Replacement, Flip your laptop over: 步骤 2 中的图像 1,1
    • Flip your laptop over so the rubber feet strips are facing up.
  3. Dell Latitude 7490 Battery Replacement, Loosen the captive screws: 步骤 3 中的图像 1,2 Dell Latitude 7490 Battery Replacement, Loosen the captive screws: 步骤 3 中的图像 2,2
    • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
  4. Dell Latitude 7490 Battery Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Insert the long side of an opening pick between the top right corner of the back cover and frame.
    • Pry the back cover up to release the clips securing the top right corner.
  5. Dell Latitude 7490 Battery Replacement, Release the clips: 步骤 5 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Release the clips: 步骤 5 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Release the clips: 步骤 5 中的图像 3,3
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Dell Latitude 7490 Battery Replacement: 步骤 6 中的图像 1,3 Dell Latitude 7490 Battery Replacement: 步骤 6 中的图像 2,3 Dell Latitude 7490 Battery Replacement: 步骤 6 中的图像 3,3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Dell Latitude 7490 Battery Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
  8. Dell Latitude 7490 Battery Replacement, Disconnect the battery: 步骤 8 中的图像 1,2 Dell Latitude 7490 Battery Replacement, Disconnect the battery: 步骤 8 中的图像 2,2
    • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
    • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
  9. Dell Latitude 7490 Battery Replacement, Unfasten the battery: 步骤 9 中的图像 1,2 Dell Latitude 7490 Battery Replacement, Unfasten the battery: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 5.7 mm‑long screws securing the battery.
  10. Dell Latitude 7490 Battery Replacement, Remove the battery: 步骤 10 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Remove the battery: 步骤 10 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Remove the battery: 步骤 10 中的图像 3,3
    • Lift the top edge of the battery.
    • Slide the battery's bottom edge out of its recess in the frame and remove the battery.
  11. Dell Latitude 7490 Battery Replacement, Reassembly information: 步骤 11 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Reassembly information: 步骤 11 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Reassembly information: 步骤 11 中的图像 3,3
    • During reassembly, slide the four plastic tabs on the bottom edge of the battery into their recesses on the frame before securing the battery.
  12. Dell Latitude 7490 Battery Replacement, Remove the battery cable: 步骤 12 中的图像 1,3 Dell Latitude 7490 Battery Replacement, Remove the battery cable: 步骤 12 中的图像 2,3 Dell Latitude 7490 Battery Replacement, Remove the battery cable: 步骤 12 中的图像 3,3
    • If your replacement battery doesn’t come with a cable preinstalled, you’ll have to transfer your original cable to the new battery.
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Flip the battery over and lay it on a clean working surface.
    • Use one hand to secure the battery.
    • Use your other hand to firmly pull the battery connector out of its socket on the bottom edge of the battery.
    • Remove the battery cable from its recess between the two battery cells.
    • During reassembly, transfer the battery cable to your new battery, making sure the cable is snug between the battery cells.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
于09/14/22注册
54,989 声望
创作了407篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,303篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 60
过去 30 天: 298
总计 2,276
