跳转到主内容
Dell Latitude 7410 Heatsink Replacement
你所需要的
  1. Dell Latitude 7410 Heatsink Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,1
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 Heatsink Replacement, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 Heatsink Replacement, Insert an opening pick: 步骤 3 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Insert an opening pick: 步骤 3 中的图像 2,2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 Heatsink Replacement, Unclip the right edge: 步骤 4 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Unclip the right edge: 步骤 4 中的图像 2,2
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 Heatsink Replacement, Unclip the left edge: 步骤 5 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Unclip the left edge: 步骤 5 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Unclip the left edge: 步骤 5 中的图像 3,3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 Heatsink Replacement, Unclip the back edge: 步骤 6 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Unclip the back edge: 步骤 6 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Unclip the back edge: 步骤 6 中的图像 3,3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 Heatsink Replacement, Unclip the front edge: 步骤 7 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Unclip the front edge: 步骤 7 中的图像 2,2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 Heatsink Replacement, Remove the back cover: 步骤 8 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Remove the back cover: 步骤 8 中的图像 2,2
    • Remove the back cover.
  9. Dell Latitude 7410 Heatsink Replacement, Disconnect the battery: 步骤 9 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Disconnect the battery: 步骤 9 中的图像 2,2
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 Heatsink Replacement, Disconnect the fan: 步骤 10 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Disconnect the fan: 步骤 10 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Disconnect the fan: 步骤 10 中的图像 3,3
    • Use a spudger to press on alternating sides of the fan connector to "walk" it out of its socket.
  11. Dell Latitude 7410 Heatsink Replacement, Remove the WLAN cable bracket: 步骤 11 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Remove the WLAN cable bracket: 步骤 11 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Remove the WLAN cable bracket: 步骤 11 中的图像 3,3
    • Use your Phillips screwdriver to remove the 3 mm screw securing the WLAN connector cover.
    • Remove the cover.
  12. Dell Latitude 7410 Heatsink Replacement, Unfasten the fan: 步骤 12 中的图像 1,1
    • Use your Phillips screwdriver to remove the two 3 mm screws securing the fan.
  13. Dell Latitude 7410 Heatsink Replacement, Remove the fan: 步骤 13 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Remove the fan: 步骤 13 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Remove the fan: 步骤 13 中的图像 3,3
    • Slide the fan out from the heatsink and remove it.
  14. Dell Latitude 7410 Heatsink Replacement, Unclip the heatsink shield: 步骤 14 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Unclip the heatsink shield: 步骤 14 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Unclip the heatsink shield: 步骤 14 中的图像 3,3
    • Use the point of your spudger to pry up the heatsink shield from its clips on the motherboard at these spots:
    • The bottom left corner, just below the white arrow
    • The bottom middle, just to the left of the QR code
    • The bottom right, just above the white arrow
    • The white arrows indicate preferred prying locations. However, prying between the shield and the motherboard at these spots risks damaging small components.
  15. Dell Latitude 7410 Heatsink Replacement, Remove the heatsink shield: 步骤 15 中的图像 1,2 Dell Latitude 7410 Heatsink Replacement, Remove the heatsink shield: 步骤 15 中的图像 2,2
    • Remove the heatsink shield.
  16. Dell Latitude 7410 Heatsink Replacement, Unfasten the heatsink: 步骤 16 中的图像 1,1
    • Use your Phillips screwdriver to remove the four 3 mm screws securing the heatsink.
    • During reassembly, tighten these screws in an X-pattern. For example, begin with the top right, then bottom left, top left, and finally bottom right to evenly compress the thermal paste.
  17. Dell Latitude 7410 Heatsink Replacement, Remove the heatsink: 步骤 17 中的图像 1,3 Dell Latitude 7410 Heatsink Replacement, Remove the heatsink: 步骤 17 中的图像 2,3 Dell Latitude 7410 Heatsink Replacement, Remove the heatsink: 步骤 17 中的图像 3,3
    • Pry the heatsink from the thermal paste bonding it to the CPU.
    • Depending on the age of your laptop, this might require some force. If it feels stuck, gently rotate it back and forth.
    • Remove the heatsink.
    • During reassembly, clean the old thermal paste from the CPU and the heatsink (if you're reusing it) and apply new thermal paste before installing your heatsink.
结论
Clay Eickemeyer
于09/19/22注册
70,402 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,076篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 205
