跳转到主内容
Dell Latitude 7410 Battery Replacement
你所需要的
  1. Dell Latitude 7410 Battery Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,1
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 Battery Replacement, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 Battery Replacement, Insert an opening pick: 步骤 3 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Insert an opening pick: 步骤 3 中的图像 2,2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 Battery Replacement, Unclip the right edge: 步骤 4 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Unclip the right edge: 步骤 4 中的图像 2,2
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 Battery Replacement, Unclip the left edge: 步骤 5 中的图像 1,3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: 步骤 5 中的图像 2,3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: 步骤 5 中的图像 3,3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 Battery Replacement, Unclip the back edge: 步骤 6 中的图像 1,3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: 步骤 6 中的图像 2,3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: 步骤 6 中的图像 3,3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 Battery Replacement, Unclip the front edge: 步骤 7 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Unclip the front edge: 步骤 7 中的图像 2,2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 Battery Replacement, Remove the back cover: 步骤 8 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Remove the back cover: 步骤 8 中的图像 2,2
    • Remove the back cover.
  9. Dell Latitude 7410 Battery Replacement, Disconnect the battery: 步骤 9 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Disconnect the battery: 步骤 9 中的图像 2,2
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 Battery Replacement, Unfasten the battery: 步骤 10 中的图像 1,1
    • Use your Phillips screwdriver to loosen the four captive screws securing the battery.
  11. Dell Latitude 7410 Battery Replacement, Remove the battery: 步骤 11 中的图像 1,2 Dell Latitude 7410 Battery Replacement, Remove the battery: 步骤 11 中的图像 2,2
    • Remove the battery.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
于09/19/22注册
66,989 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,298篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 68
总计 532
