跳转到主内容
加入维修社区 - 创建账户
Dell Latitude 5580 RAM Replacement
你所需要的
  1. Dell Latitude 5580 RAM Replacement, RAM: 步骤 1 中的图像 1,3 Dell Latitude 5580 RAM Replacement, RAM: 步骤 1 中的图像 2,3 Dell Latitude 5580 RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Orient your laptop so you can access the bottom cover, with the fan vents facing upwards.
    • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
    • Remove the bottom cover.
    询问修复机器人
    添加评论
  2. Dell Latitude 5580 RAM Replacement: 步骤 2 中的图像 1,3 Dell Latitude 5580 RAM Replacement: 步骤 2 中的图像 2,3 Dell Latitude 5580 RAM Replacement: 步骤 2 中的图像 3,3
    • Push the clips on the side of the RAM out a few millimeters to release the RAM stick.
    • It will pop up at a 45 degree angle.
    • Hold the edges of the RAM stick and slide it out of the socket.
    • Be careful when replacing the new RAM that you line up the connector edge with the socket to avoid bending them. Once it is inserted, press down until it clicks and the arms securely hold the RAM stick.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 36
总计 338
