跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron Duo RAM Replacement
你所需要的
  1. Dell Inspiron Duo RAM Replacement, Front Cover: 步骤 1 中的图像 1,2 Dell Inspiron Duo RAM Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
    添加评论
  2. Dell Inspiron Duo RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron Duo RAM Replacement: 步骤 2 中的图像 2,2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
    添加评论
  3. Dell Inspiron Duo RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron Duo RAM Replacement: 步骤 3 中的图像 2,2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
    添加评论
  4. Dell Inspiron Duo RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • With the cover removed, locate the 2GB RAM stick. It will be in the upper-middle portion of the device. The RAM stick is the flat blue rectangular object that has four black squares running along it vertically (for convenience, the RAM stick has been outlined in red in the photo).
    询问修复机器人
    添加评论
  5. Dell Inspiron Duo RAM Replacement: 步骤 5 中的图像 1,2 Dell Inspiron Duo RAM Replacement: 步骤 5 中的图像 2,2
    • There are two white spring levers on either side of the RAM. Pull them out gently to release the RAM. This will cause the RAM to stick up at a forty-five degree angle.
    • With the RAM at a forty-five degree angle, gently pull it straight out of the device.
    询问修复机器人
    添加评论
  6. Dell Inspiron Duo RAM Replacement: 步骤 6 中的图像 1,2 Dell Inspiron Duo RAM Replacement: 步骤 6 中的图像 2,2
    • With the RAM stick flipped up, carefully lift it out of the slot.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015 的会员
UWT-LINER-SU15S1G1
3 名成员
创作了6篇指南
2指南评论
Good effort, but incomplete. Laptop parts can be very easily damaged, so removing all the screws is important.
Chiel Kersten - 回复 分享
Good evening!!!
Is it possible to install a M.2 or NVME SSD in this netbook model?
Greetings and blessings from Venezuela!!!!
Edwin Guerra Avendaño - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 40
总计 2,786
