跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 9300 Trackpad Replacement
你所需要的
    1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
      • Remove the battery in to order avoid damaging internal components.
      询问修复机器人
      添加评论
    2. Dell Inspiron 9300 Trackpad Replacement: 步骤 2 中的图像 1,1
      • Remove the twelve 6mm Phillips screws from the bottom of the case.
      询问修复机器人
      添加评论
    3. Dell Inspiron 9300 Trackpad Replacement: 步骤 3 中的图像 1,1
      • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
      • There is a notch on the right-hand side of the bezel for easiest removal.
      询问修复机器人
      添加评论
    4. Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 3,3
      • Remove the two 5mm Phillips screws retaining the keyboard.
      • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
      • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
      询问修复机器人
      添加评论
    5. Dell Inspiron 9300 Trackpad Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 5 中的图像 2,2
      • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
      • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
      • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
      询问修复机器人
      添加评论
    6. Dell Inspiron 9300 Trackpad Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 6 中的图像 2,2
      • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
      • Gently pry the CMOS battery out of its retaining clip using a spudger.
      询问修复机器人
      添加评论
    7. Dell Inspiron 9300 Trackpad Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 7 中的图像 2,2
      • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
      • Remove the trackpad ribbon cable from the motherboard using a spudger.
      询问修复机器人
      添加评论
    8. Dell Inspiron 9300 Trackpad Replacement: 步骤 8 中的图像 1,1
      • Pull up and away on the upper case to remove.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G6
5 名成员
创作了99篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 511
