跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 3520 Keyboard Replacement
你所需要的
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 3520 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
    询问修复机器人
    添加评论
  2. Dell Inspiron 3520 Keyboard Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 3520 Keyboard Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 3520 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
    询问修复机器人
    添加评论
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
    询问修复机器人
    添加评论
  4. Dell Inspiron 3520 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
    询问修复机器人
    添加评论
  5. Dell Inspiron 3520 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 3520 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Ian
于01/30/15注册
1,638 声望
创作了5篇指南
团队
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G2
3 名成员
创作了5篇指南
1指南评论
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 52
总计 7,182
