跳转到主内容
Dell Inspiron 3501 Battery Replacement
你所需要的
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: 步骤 2 中的图像 1,2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: 步骤 2 中的图像 2,2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: 步骤 3 中的图像 1,2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: 步骤 3 中的图像 2,2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 1,2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 2,2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: 步骤 6 中的图像 1,2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: 步骤 6 中的图像 2,2
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: 步骤 7 中的图像 1,3 Dell Inspiron 3501 Battery Replacement, Remove the battery: 步骤 7 中的图像 2,3 Dell Inspiron 3501 Battery Replacement, Remove the battery: 步骤 7 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
于01/16/22注册
124,699 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,303篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 74
总计 1,214
