跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1546 Memory Module Replacement
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1546 Memory Module Replacement, Popping up the Memory Module: 步骤 2 中的图像 1,1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1546 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 1,2 Dell Inspiron 1546 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 2,2
      • Align the notch in the NEW memory module with the tab in the memory module connector.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1546 Memory Module Replacement, Sliding the Module: 步骤 4 中的图像 1,1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
Terrence15
于12/18/17注册
80,125 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了8,882篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 20
总计 230
