跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1545 Display Replacement
你所需要的
    1. Dell Inspiron 1545 Display Replacement, Battery: 步骤 1 中的图像 1,1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1545 Display Replacement: 步骤 2 中的图像 1,1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1545 Display Replacement: 步骤 3 中的图像 1,1
      • Slide the battery out of the battery bay.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1545 Display Replacement, Center Control Cover: 步骤 4 中的图像 1,1
      • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1545 Display Replacement: 步骤 5 中的图像 1,1
      • Flip the laptop over to the front and open the display as far as possible.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1545 Display Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 1545 Display Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 1545 Display Replacement: 步骤 6 中的图像 3,3
      • The Center Control Cover is VERY fragile, be careful when using prying tools.
      • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
      • Carefully lift the Center Control Cover away from the laptop.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1545 Display Replacement, Keyboard: 步骤 7 中的图像 1,1
      • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1545 Display Replacement: 步骤 8 中的图像 1,1
      • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
      • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1545 Display Replacement: 步骤 9 中的图像 1,1
      • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
      添加评论
    4. Dell Inspiron 1545 Display Replacement: 步骤 10 中的图像 1,1
      • Lift the keyboard up and away from the laptop.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1545 Display Replacement, Display: 步骤 11 中的图像 1,1
      • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
      添加评论
    2. Dell Inspiron 1545 Display Replacement: 步骤 12 中的图像 1,1
      • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
      • Unwind the wires so they can be freely pulled through in the next step.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1545 Display Replacement: 步骤 13 中的图像 1,1
      • Turn the laptop over to its standard position.
      • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
      • Pull the black and white wires previously connected to the WLAN through the hole.
      询问修复机器人
      添加评论
    4. Dell Inspiron 1545 Display Replacement: 步骤 14 中的图像 1,1
      • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
      • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
      询问修复机器人
      添加评论
    5. Dell Inspiron 1545 Display Replacement: 步骤 15 中的图像 1,1
      • Lift the display assembly off the computer.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
Nathan Lemay
于04/16/14注册
3,160 声望
创作了15篇指南
团队
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G14
4 名成员
创作了90篇指南
3指南评论
wow that is really good
Mck - Isolutions - 回复 分享
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
Kumar Bhrigu - 回复 分享
put it back toghther, then plug in a external monitor
Feyrowan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 42
总计 6,471
