跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1525 Keyboard Replacement
你所需要的
    1. Dell Inspiron 1525 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Locate the battery release switch on the bottom of the laptop.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1525 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 1525 Keyboard Replacement: 步骤 2 中的图像 2,2
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1525 Keyboard Replacement, Central Control Cover: 步骤 3 中的图像 1,1
      • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1525 Keyboard Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 1525 Keyboard Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 1525 Keyboard Replacement: 步骤 4 中的图像 3,3
      • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
      • Carefully pull the central control cover up along its edges.
      • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
      询问修复机器人
      添加评论
    3. Dell Inspiron 1525 Keyboard Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 1525 Keyboard Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 1525 Keyboard Replacement: 步骤 5 中的图像 3,3
      • Peel back the silver tape securing the ribbon cable to the cover.
      • Pull the small brown latch on the ribbon cable connector out.
      • Disconnect the ribbon cable to completely free the central control cover.
      询问修复机器人
      添加评论
    1. Dell Inspiron 1525 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,2 Dell Inspiron 1525 Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,2
      • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
      • Gently slide the keyboard towards the display until the tabs on its front side are free.
      • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
      询问修复机器人
      添加评论
    2. Dell Inspiron 1525 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 1525 Keyboard Replacement: 步骤 7 中的图像 2,2
      • Use a spudger to gently lift the ribbon cable retaining flap.
      • Disconnect the ribbon cable.
      • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
3指南评论
why did you say to remove the central control cover? It is so hard top get it back! Especially when the guide on laptopkeyboard.com seems to suggest that this is unnecessary.
sally wise - 回复 分享
Thank you so much…!
amal. k.manoj - 回复 分享
thanks, marvelous site . I am in
Nasser Dardier - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 51
总计 14,842
