跳转到主内容
Dell Inspiron 15-7547 Battery Replacement
你所需要的
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15-7547 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7547 Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15-7547 Battery Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15-7547 Battery Replacement: 步骤 5 中的图像 3,3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 24
总计 2,089
