跳转到主内容
Dell Inspiron 14z Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 3 中的图像 3,3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 14z Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: 步骤 5 中的图像 1,1
    • The hard drive is now removed from the caddy and the replacement can be installed.
结论
2等其他人完成本指南。
oldturkey03
于09/29/10注册
791,325 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 12,802
