跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
你所需要的
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
    询问修复机器人
    添加评论
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
    询问修复机器人
    添加评论
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the rest of the device.
    添加评论
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 1,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 2,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 3,3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
    询问修复机器人
    添加评论
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 5 中的图像 1,1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
4指南评论
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - 回复 分享
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - 回复 分享
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - 回复 分享
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 3,688
