跳转到主内容
Dell Inspiron 13-5368 Battery Replacement
你所需要的
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 13-5368 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-5368 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13-5368 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
14等其他人完成本指南。
Matt Sugrim
于09/27/17注册
1,042 声望
创作了6篇指南
团队
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G6
4 名成员
创作了13篇指南
3条评论
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - 回复
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - 回复
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 152
总计 24,787
