跳转到主内容
Dell Inspiron 11-3168 Battery Replacement
你所需要的
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11-3168 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 11-3168 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 11-3168 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11-3168 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 11-3168 Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 11-3168 Battery Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 11-3168 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
4等其他人完成本指南。
2条评论
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - 回复
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 936
