跳转到主内容
加入维修社区 - 创建账户
Dell Dimension 4600 Fan Replacement
  1. Dell Dimension 4600 Fan Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Locate the case cover latch on the back of the computer.
    询问修复机器人
    添加评论
  2. Dell Dimension 4600 Fan Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    询问修复机器人
    添加评论
  3. Dell Dimension 4600 Fan Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the panel and slide it away from the case until it is removed.
    询问修复机器人
    添加评论
  4. Dell Dimension 4600 Fan Replacement, Fan: 步骤 4 中的图像 1,1
    • Lay the computer flat on it's side so that you are looking down at all of the components.
    • Locate the fan and its black, red, and white power cable.
    询问修复机器人
    添加评论
  5. Dell Dimension 4600 Fan Replacement: 步骤 5 中的图像 1,1
    • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
    询问修复机器人
    添加评论
  6. Dell Dimension 4600 Fan Replacement: 步骤 6 中的图像 1,1
    • Locate the release clip on the side of the fan and hold it down with your thumb.
    询问修复机器人
    添加评论
  7. Dell Dimension 4600 Fan Replacement: 步骤 7 中的图像 1,1
    • While holding the release clip down, look on the outside of the case where the fan lies.
    • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Tim
于10/12/11注册
76 声望
撰写一个指南
团队
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G10
4 名成员
创作了11篇指南
1指南评论
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 6,542
