跳转到主内容
加入维修社区 - 创建账户
Dell Alienware M11x R3 2.5" Hard Drive Replacement
你所需要的
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 1,3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 2,3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
    询问修复机器人
    添加评论
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • Remove the three screws attaching the hard drive tray to the laptop.
    询问修复机器人
    添加评论
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
    询问修复机器人
    添加评论
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 4 中的图像 2,2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
    询问修复机器人
    添加评论
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,038
