跳转到主内容
加入维修社区 - 创建账户
Dell Alienware 15 R3 Battery Replacement
你所需要的
    1. Dell Alienware 15 R3 Battery Replacement, Back Case: 步骤 1 中的图像 1,3 Dell Alienware 15 R3 Battery Replacement, Back Case: 步骤 1 中的图像 2,3 Dell Alienware 15 R3 Battery Replacement, Back Case: 步骤 1 中的图像 3,3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      添加评论
    2. Dell Alienware 15 R3 Battery Replacement: 步骤 2 中的图像 1,1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      询问修复机器人
      添加评论
    1. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: 步骤 3 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
      询问修复机器人
      添加评论
    2. Dell Alienware 15 R3 Battery Replacement: 步骤 4 中的图像 1,2 Dell Alienware 15 R3 Battery Replacement: 步骤 4 中的图像 2,2
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
      询问修复机器人
      添加评论
    3. Dell Alienware 15 R3 Battery Replacement: 步骤 5 中的图像 1,3 Dell Alienware 15 R3 Battery Replacement: 步骤 5 中的图像 2,3 Dell Alienware 15 R3 Battery Replacement: 步骤 5 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
      添加评论
    1. Dell Alienware 15 R3 Battery Replacement, Battery: 步骤 6 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
      询问修复机器人
      添加评论
    2. Dell Alienware 15 R3 Battery Replacement: 步骤 7 中的图像 1,3 Dell Alienware 15 R3 Battery Replacement: 步骤 7 中的图像 2,3 Dell Alienware 15 R3 Battery Replacement: 步骤 7 中的图像 3,3
      • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
      • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
2指南评论
does not seem to be for my alienware r3 15 inch
Craig Anderson - 回复 分享
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 180
总计 10,544
