跳转到主内容
加入维修社区 - 创建账户
Dell Alienware 15 Memory Module Replacement
你所需要的
    • After turning the computer off, close the display and turn the computer over.
    询问修复机器人
    添加评论
  1. Dell Alienware 15 Memory Module Replacement, Remove the Back Panel Screws and Lift: 步骤 2 中的图像 1,1
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
    询问修复机器人
    添加评论
  2. Dell Alienware 15 Memory Module Replacement, Optional: Disconnect the Battery: 步骤 3 中的图像 1,1
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
    询问修复机器人
    添加评论
  3. Dell Alienware 15 Memory Module Replacement, Memory Securing Clips: 步骤 4 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
    添加评论
  4. Dell Alienware 15 Memory Module Replacement, Remove Memory Module: 步骤 5 中的图像 1,1
    • Slide and remove the memory module from any memory-module slots that you would like to repopulate.
    询问修复机器人
    添加评论
  5. Dell Alienware 15 Memory Module Replacement, Adding New Memory Module: 步骤 6 中的图像 1,1
    • Align the notch on the New memory module with the tab on the memory- module slot.
    询问修复机器人
    添加评论
  6. Dell Alienware 15 Memory Module Replacement, Firmly Press the Memory Module Down.: 步骤 7 中的图像 1,1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place. Do this individually for each memory module that is replaced.
    • NOTE : If you do not hear the click, remove the memory module and reinstall it.
    询问修复机器人
    添加评论
结论
To reassemble your device, screw the base panel on again.
取消:我没有完成这个指南。
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
46,158 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,003篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 43
总计 948
