跳转到主内容
加入维修社区 - 创建账户
Dell AC511 Volume Knob Replacement
你所需要的
  1. Dell AC511 Volume Knob Replacement, Front Panel: 步骤 1 中的图像 1,3 Dell AC511 Volume Knob Replacement, Front Panel: 步骤 1 中的图像 2,3 Dell AC511 Volume Knob Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
    询问修复机器人
    添加评论
  2. Dell AC511 Volume Knob Replacement: 步骤 2 中的图像 1,2 Dell AC511 Volume Knob Replacement: 步骤 2 中的图像 2,2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  3. Dell AC511 Volume Knob Replacement: 步骤 3 中的图像 1,2 Dell AC511 Volume Knob Replacement: 步骤 3 中的图像 2,2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
    询问修复机器人
    添加评论
  4. Dell AC511 Volume Knob Replacement, Volume Knob: 步骤 4 中的图像 1,1
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
    询问修复机器人
    添加评论
  5. Dell AC511 Volume Knob Replacement: 步骤 5 中的图像 1,1
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
William Cook
于03/19/24注册
653 声望
创作了6篇指南
团队
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G6
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 30
总计 366
