跳转到主内容
加入维修社区 - 创建账户
DeWalt DW997 Forward/Reverse Switch Replacement
你所需要的
  1. DeWalt DW997 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: 步骤 1 中的图像 1,1
    • There should be 7 screws that are 21 mm long, remove them with a TorxT15 bit.
    • There should be 1 screw that is 18 mm long, remove it with a Torx T10 bit.
    • Note: Keep all 8 screws together to avoid losing them .
    添加评论
  2. DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 2 中的图像 1,2 DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 2 中的图像 2,2
    • Once all screws are removed, remove the plastic siding by slowly prying open the two sides all the way around.
    • Caution: Do not pry the two pieces apart with a tool. Once all the screws are out, the two parts should split.
    询问修复机器人
    添加评论
  3. DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 3 中的图像 1,3 DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 3 中的图像 2,3 DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 3 中的图像 3,3
    • Locate the forward/reverse switch above the trigger. Lift up the copper colored trigger assembly and lift up the switch with two fingers.
    • Note: The switch should easily come out.
    询问修复机器人
    添加评论
  4. DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 4 中的图像 1,2 DeWalt DW997 Forward/Reverse Switch  Replacement: 步骤 4 中的图像 2,2
    • Take the replacement switch and place it in the trigger assembly that the faulty switch was removed from. The new switch has two legs on one side, the bigger triangular shaped leg should be towards the front of the drill.
    • Note: The side of the switch that has the two legs is placed facing down.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 46
总计 4,648
