跳转到主内容
Dashcam DOD LS300W Battery Replacement
你所需要的
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 步骤 1 中的图像 1,3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 步骤 1 中的图像 2,3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 步骤 1 中的图像 3,3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: 步骤 2 中的图像 1,2 Dashcam DOD LS300W Battery Replacement: 步骤 2 中的图像 2,2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: 步骤 3 中的图像 1,3 Dashcam DOD LS300W Battery Replacement: 步骤 3 中的图像 2,3 Dashcam DOD LS300W Battery Replacement: 步骤 3 中的图像 3,3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: 步骤 4 中的图像 1,1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
结论
Once again, thank you for checking out this guide and I hope it helped!
2等其他人完成本指南。
Pierre
于04/02/13注册
542 声望
创作了3篇指南
2条评论
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - 回复
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 41
总计 6,370
