跳转到主内容
加入维修社区 - 创建账户
DOSS SoundBox Speaker Replacement
你所需要的
    1. DOSS SoundBox Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 DOSS SoundBox Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      询问修复机器人
      添加评论
    2. DOSS SoundBox Speaker Replacement: 步骤 2 中的图像 1,2 DOSS SoundBox Speaker Replacement: 步骤 2 中的图像 2,2
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      询问修复机器人
      添加评论
    3. DOSS SoundBox Speaker Replacement: 步骤 3 中的图像 1,2 DOSS SoundBox Speaker Replacement: 步骤 3 中的图像 2,2
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      添加评论
结论
To reassemble your device, follow instructions in reverse order.
取消:我没有完成这个指南。
2等其他人完成本指南。
1指南评论
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 44
总计 3,708
