简介
This guide will help you replace or remove the base plate on your DOSS SoundBox portable Bluetooth speaker, which provides structural integrity and protects the device's internal components. The base plate may need replacement if your speaker shows signs of physical instability or sound distortion coming from the base of the speaker. Before starting, ensure the device is powered off to avoid accidental damage.
你所需要的
Locate the four 3/32" screws on the bottom of your device.
Using a JIS #00 screwdriver, remove the four 3/32" screws.
After removing the screws, lift the cover off of the device.
3等其他人完成本指南。
