跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
你所需要的
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      询问修复机器人
      添加评论
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 2 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 2 中的图像 2,2
      • Remove three screws using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 3 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      询问修复机器人
      添加评论
    4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 4 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 4 中的图像 2,2
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      询问修复机器人
      添加评论
    5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 5 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 5 中的图像 2,2
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      询问修复机器人
      添加评论
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: 步骤 6 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: 步骤 6 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
      询问修复机器人
      添加评论
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 步骤 7 中的图像 1,1
      • Remove back buttons and replace with new ones.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 40
总计 842
