跳转到主内容
DCC-3200 Faulty Power Cord Replacement
你所需要的
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: 步骤 1 中的图像 1,1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: 步骤 2 中的图像 1,1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: 步骤 4 中的图像 1,1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: 步骤 6 中的图像 1,1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: 步骤 7 中的图像 1,1
    • Strip the wire and twist with the other or solder it back on.
结论
另外一个人完成了本指南。
Hamad Khan
于03/04/16注册
385 声望
创作了3篇指南
团队
UMass Dartmouth, Team 8-3, Botvin Spring 2016 UMass Dartmouth, Team 8-3, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 2,017
