简介
The heat sink is responsible for regulating the heat flow and temperature control in your device. If your device is overheating and not cooling itself down properly, then the heat sink will need to be replaced. Follow this guide for the steps on how to replace the heat sink.
你所需要的
Unscrew the two 7mm screws with a Phillips #1 screwdriver.
Lift the heat sink off the metal plate with your fingers.
另外一个人完成了本指南。
