跳转到主内容
加入维修社区 - 创建账户
CyberPowerPC RGB 7 Color Key Replacement Replacement
你所需要的
  1. CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: 步骤 1 中的图像 1,2 CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: 步骤 1 中的图像 2,2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    询问修复机器人
    添加评论
  2. CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 2 中的图像 1,2 CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 2 中的图像 2,2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
    询问修复机器人
    添加评论
  3. CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 3 中的图像 1,1
    • Lift up and remove the plastic casing.
    询问修复机器人
    添加评论
  4. CyberPowerPC RGB 7 Color Key Replacement Replacement, LED Backlight: 步骤 4 中的图像 1,1
    • Remove the metal backing located directly underneath the white plastic casing.
    询问修复机器人
    添加评论
  5. CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 5 中的图像 1,1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
    询问修复机器人
    添加评论
  6. CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the LED board, which should now come free from the casing.
    询问修复机器人
    添加评论
  7. CyberPowerPC RGB 7 Color Key Replacement Replacement, Key Replacement: 步骤 7 中的图像 1,1
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
    询问修复机器人
    添加评论
  8. CyberPowerPC RGB 7 Color Key Replacement Replacement: 步骤 8 中的图像 1,1
    • The keyboard should now be free to move, pick up the entire keyboard membrane and search for the key that needs to be replaced, to assist in remembering which key needs to be replaced place a small marker dot on the individual key back.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team S15-G2, Boczar Spring 2018 USF Tampa, Team S15-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G2
4 名成员
创作了10篇指南
1指南评论
Gooooooooooooooooood
صلاح الدين الحبيشي - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 51
总计 4,170
