跳转到主内容
加入维修社区 - 创建账户
Creative Ziio 7" Motherboard Replacement
你所需要的
    1. Creative Ziio 7" Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Creative Ziio 7" Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Creative Ziio 7" Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      询问修复机器人
      添加评论
    1. Creative Ziio 7" Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Creative Ziio 7" Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Creative Ziio 7" Motherboard Replacement, Motherboard: 步骤 2 中的图像 3,3
      • Remove the copper plate covering the motherboard by desoldering the ten solder points.
      • The solder point in the bottom right corner is marked but hidden by the soldering iron.
      询问修复机器人
      添加评论
    2. Creative Ziio 7" Motherboard Replacement: 步骤 3 中的图像 1,2 Creative Ziio 7" Motherboard Replacement: 步骤 3 中的图像 2,2
      • Remove the adhesive tape covering the three wires connected to the motherboard.
      • Desolder the solder points connecting the wires to the motherboard.
      询问修复机器人
      添加评论
    3. Creative Ziio 7" Motherboard Replacement: 步骤 4 中的图像 1,3 Creative Ziio 7" Motherboard Replacement: 步骤 4 中的图像 2,3 Creative Ziio 7" Motherboard Replacement: 步骤 4 中的图像 3,3
      • Disconnect the ribbon cable that is attached underneath the copper plate.
      • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
      询问修复机器人
      添加评论
    4. Creative Ziio 7" Motherboard Replacement: 步骤 5 中的图像 1,2 Creative Ziio 7" Motherboard Replacement: 步骤 5 中的图像 2,2
      • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
      • The copper plate will be removed by now. However, the picture does not show this.
      询问修复机器人
      添加评论
    5. Creative Ziio 7" Motherboard Replacement: 步骤 6 中的图像 1,2 Creative Ziio 7" Motherboard Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Lift up the motherboard.
      • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
      • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
      询问修复机器人
      添加评论
    6. Creative Ziio 7" Motherboard Replacement: 步骤 7 中的图像 1,1
      • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
      • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
      询问修复机器人
      添加评论
    7. Creative Ziio 7" Motherboard Replacement: 步骤 8 中的图像 1,1
      • Remove the old motherboard and dispose of it resposibly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G10
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 1,463
