跳转到主内容
加入维修社区 - 创建账户
Creative Zen Vision W Battery Replacement
你所需要的
  1. Creative Zen Vision W Battery Replacement, Battery Removal: 步骤 1 中的图像 1,3 Creative Zen Vision W Battery Replacement, Battery Removal: 步骤 1 中的图像 2,3 Creative Zen Vision W Battery Replacement, Battery Removal: 步骤 1 中的图像 3,3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
    询问修复机器人
    添加评论
  2. Creative Zen Vision W Battery Replacement, Battery: 步骤 2 中的图像 1,2 Creative Zen Vision W Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
    添加评论
  3. Creative Zen Vision W Battery Replacement: 步骤 3 中的图像 1,3 Creative Zen Vision W Battery Replacement: 步骤 3 中的图像 2,3 Creative Zen Vision W Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
    询问修复机器人
    添加评论
结论
Follow these instructions in reverse order to reassemble your device.
取消:我没有完成这个指南。
2等其他人完成本指南。
Tim Wilson
于04/11/13注册
143 声望
创作了6篇指南
团队
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G2
4 名成员
创作了16篇指南
3指南评论
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - 回复 分享
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - 回复 分享
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 66
总计 7,195
