跳转到主内容
加入维修社区 - 创建账户
Creative Zen Vision M Screen Replacement
你所需要的
    1. Creative Zen Vision M Screen Replacement, Opening the top: 步骤 1 中的图像 1,2 Creative Zen Vision M Screen Replacement, Opening the top: 步骤 1 中的图像 2,2
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      询问修复机器人
      添加评论
    2. Creative Zen Vision M Screen Replacement, Opening the device: 步骤 2 中的图像 1,2 Creative Zen Vision M Screen Replacement, Opening the device: 步骤 2 中的图像 2,2
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      询问修复机器人
      添加评论
    3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 1,3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 2,3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 步骤 3 中的图像 3,3
      • Disconnect the wire from the bottom device.
      • Handle with care as the wires tend to disconnect easily.
      询问修复机器人
      添加评论
    4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: 步骤 4 中的图像 1,1
      • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
      • Handle with care as the hard drive also comes off easily.
      询问修复机器人
      添加评论
    5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: 步骤 5 中的图像 1,1
      • Unscrew the seven screws placed around the mother board.
      • You will need a one millimeter Phillips head screwdriver.
      • The screws are small, so keep them safely.
      询问修复机器人
      添加评论
    6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 1,3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 2,3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 步骤 6 中的图像 3,3
      • Flip your device upside down so that the motherboard will loosen.
      • Detach the connector from the motherboard.
      询问修复机器人
      添加评论
    7. Creative Zen Vision M Screen Replacement, Removing the screen: 步骤 7 中的图像 1,2 Creative Zen Vision M Screen Replacement, Removing the screen: 步骤 7 中的图像 2,2
      • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
      • Lift the light gray flap to detach the screen from the motherboard.
      询问修复机器人
      添加评论
    8. Creative Zen Vision M Screen Replacement, Seperating the digital display: 步骤 8 中的图像 1,2 Creative Zen Vision M Screen Replacement, Seperating the digital display: 步骤 8 中的图像 2,2
      • Separate the clear screen frame from the digital display.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kirstie G
于10/12/16注册
491 声望
创作了4篇指南
团队
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G1
4 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 56
总计 2,018
