跳转到主内容
加入维修社区 - 创建账户
Cr-48 Chromebook Network Card Replacement
你所需要的
  1. Cr-48 Chromebook Network Card Replacement, Battery: 步骤 1 中的图像 1,3 Cr-48 Chromebook Network Card Replacement, Battery: 步骤 1 中的图像 2,3 Cr-48 Chromebook Network Card Replacement, Battery: 步骤 1 中的图像 3,3
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    询问修复机器人
    添加评论
  2. Cr-48 Chromebook Network Card Replacement, Bottom Casing: 步骤 2 中的图像 1,2 Cr-48 Chromebook Network Card Replacement, Bottom Casing: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    询问修复机器人
    添加评论
  3. Cr-48 Chromebook Network Card Replacement: 步骤 3 中的图像 1,3 Cr-48 Chromebook Network Card Replacement: 步骤 3 中的图像 2,3 Cr-48 Chromebook Network Card Replacement: 步骤 3 中的图像 3,3
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    询问修复机器人
    添加评论
  4. Cr-48 Chromebook Network Card Replacement: 步骤 4 中的图像 1,3 Cr-48 Chromebook Network Card Replacement: 步骤 4 中的图像 2,3 Cr-48 Chromebook Network Card Replacement: 步骤 4 中的图像 3,3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    询问修复机器人
    添加评论
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 步骤 5 中的图像 1,3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 步骤 5 中的图像 2,3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 步骤 5 中的图像 3,3
    • With the lower case removed, look for the network card. It’s typically located in the corner near one of the USB ports.
    • Use tweezers or forceps to carefully lift off the wire connectors attached to the network card.
    • Take note of which wire went to which terminal (e.g., left vs. right).
    询问修复机器人
    添加评论
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 步骤 6 中的图像 1,3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 步骤 6 中的图像 2,3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 步骤 6 中的图像 3,3
    • Remove the single 3 mm screw securing the network card to the board.
    • Once the screw is out, the card should pivot upward slightly (“pop up”).
    • Gently pull the network card out of its socket at an angle and remove it completely.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an E-Waste certified recycler.
取消:我没有完成这个指南。
团队
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G2
3 名成员
创作了10篇指南
1指南评论
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 31
总计 1,465
