跳转到主内容
加入维修社区 - 创建账户
Controller Plate/Buttons Replacement
你所需要的
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: 步骤 1 中的图像 1,1
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    询问修复机器人
    添加评论
  2. Controller Plate/Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    询问修复机器人
    添加评论
  3. Controller Plate/Buttons Replacement: 步骤 3 中的图像 1,1
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    询问修复机器人
    添加评论
  4. Controller Plate/Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    询问修复机器人
    添加评论
  5. Controller Plate/Buttons Replacement: 步骤 5 中的图像 1,1
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    添加评论
  6. Controller Plate/Buttons Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    询问修复机器人
    添加评论
  7. Controller Plate/Buttons Replacement: 步骤 7 中的图像 1,1
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G3
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 60
总计 1,843
