跳转到主内容
加入维修社区 - 创建账户
Contour Roam2 Mounting Piece Replacement
你所需要的
    1. Contour Roam2 Mounting Piece Replacement, Record Slider: 步骤 1 中的图像 1,1
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      询问修复机器人
      添加评论
    2. Contour Roam2 Mounting Piece Replacement: 步骤 2 中的图像 1,2 Contour Roam2 Mounting Piece Replacement: 步骤 2 中的图像 2,2
      • Rotate the metal ring counterclockwise until completely removed.
      询问修复机器人
      添加评论
    3. Contour Roam2 Mounting Piece Replacement: 步骤 3 中的图像 1,2 Contour Roam2 Mounting Piece Replacement: 步骤 3 中的图像 2,2
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      询问修复机器人
      添加评论
    4. Contour Roam2 Mounting Piece Replacement: 步骤 4 中的图像 1,3 Contour Roam2 Mounting Piece Replacement: 步骤 4 中的图像 2,3 Contour Roam2 Mounting Piece Replacement: 步骤 4 中的图像 3,3
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      询问修复机器人
      添加评论
    5. Contour Roam2 Mounting Piece Replacement: 步骤 5 中的图像 1,1
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      询问修复机器人
      添加评论
    1. Contour Roam2 Mounting Piece Replacement, Mounting Piece: 步骤 6 中的图像 1,2 Contour Roam2 Mounting Piece Replacement, Mounting Piece: 步骤 6 中的图像 2,2
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      询问修复机器人
      添加评论
    2. Contour Roam2 Mounting Piece Replacement: 步骤 7 中的图像 1,2 Contour Roam2 Mounting Piece Replacement: 步骤 7 中的图像 2,2
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      询问修复机器人
      添加评论
    3. Contour Roam2 Mounting Piece Replacement: 步骤 8 中的图像 1,1
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      询问修复机器人
      添加评论
    4. Contour Roam2 Mounting Piece Replacement: 步骤 9 中的图像 1,2 Contour Roam2 Mounting Piece Replacement: 步骤 9 中的图像 2,2
      • Remove and replace mount piece.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G5
3 名成员
创作了30篇指南
2指南评论
Hi i need this part...
julmarte - 回复 分享
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
Dudley Walsh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 11
过去 30 天: 37
总计 1,938
